Results 1 to 18 of 18
Thread: 1450 Mod prop - anyone use one ?
    ca
    6,962
    Default 1450 Mod prop - anyone use one ?
    I just bumped into a vendor offering a 1450 "Mod" prop B&S ; looks like it might be a good P-Sport Hydro candidate
    46.5 mm ; 2.75 pitch
    Anyone have actual experience with one ? LMK
    Thanks,
    Tony
    Mar 2007
    VA
    7,212
    I have one. I like it a lot. It's been on a JAE21FE and a Rigged Insanity
    ca
    6,962
    Quote Originally Posted by Diegoboy View Post
    Thanks Danny. Are you using it with a spec setup ? Any lift issues ?
    Both the 1400 and 1600 series can be delifted to match the lift of an X prop. Because of the different distribution of blade area nearer the tips when compared to the X, these props can harness motor power better - if you have the power. I run a cupped 1650 on my Q Sport hydro with good results. I use a Grim 42x66 on my FE-30 P Limited, delifted I prefer it to the m445 as it seems to handle a bit better and is a tad faster.
    Jun 2008
    GA
    2,318
    If hull is not too heavy I keep thinking the ABC 1816-10-50 (3 blade, 45.72mm, 2.880" pitch) would be a good prop using the UL-1 motor/esc in P SPORT HYDRO. Tony, How much does your insane 30" weigh RTR?
    Jun 2008
    GA
    2,318
    I have also been wanting to try the ABC 1816/3 prop in my UL powered Raptor Rigger.
    Mar 2007
    VA
    7,212
    Thank you for the information Jay.
    The JAE was not a spec setup, but the Insanity was.
    Jan 2008
    VA
    3,070
    I have a cut down Sholund 1450 I have used in the Spec JAE but the two H7's I have (Sholund and Andy Brown) are a couple mph faster.
    I have tried a ABC 1714 in my Spec FE30 (UL1 motor and controller). The boat was a rocket but the motor was pushing 140 after four laps. ABC props will put much more load on the motor than a Octura X and M series with similar numbers.
    Us Spec controller guys cant go much bigger than a 42x55 or 442 without
    Va
    4,670
    Yes it is and it was flat in the straights and the turns.
    IMPBA 20481S D-12
    ca
    6,962
    Quote Originally Posted by detox View Post
    My spec FE30 fully rigged with a UL1 motor & speedy weighs 4.1 lbs (minus battery)
    My P-Sport FE30 fully rigged with Neu 1515 & T-180 weighs 6.38 lbs (minus batteries & prop)
    Jun 2008
    GA
    2,318
    Tony, Thanks for answering and correcting me on the class.
    Keith
    Jun 2008
    GA
    2,318
    BTW my P-Sport Whiplash fully rigged with Castle 1515 & Hydra LV 240 weighs 5.6 lbs (minus batteries & prop)
    ca
    6,962
    Yup, the Whip's are light ! But actually, I've been racing in gasserwater ( last race we followed three heats of those monstrous gas Thunderboats) and with
    2 X 4S 4000's the extra weight helps keep it on the water in the slop. In fact Mark F turned me on to a tip : put some weight ( I use @ 8 oz. in the left sponson) to keep the sponson from lifting when my rather agressive race props hit hard.
    Jul 2010
    409
    Thanks,
    Tony
    I have the same prop...got it for my JAE21 (waiting for paint), and thought about trying on my FE-30. If you run it, let us know...and it was only 12 bucks!
    Support US hobby suppliers
    Jun 2008
    GA
    2,318
    I have a total of 4 ozs (2oz in each sponson tip). I will try 4 more ozs on the left sponson and two Thunderpower 4s 4000mah packs.
    Thanks!
    Mar 2007
    VA
    7,212
    Quote Originally Posted by egneg View Post
    Sorry about that Chuck, I was mistaken. It was the tunnel that's not spec.
    ca
    6,962
    Quote Originally Posted by Insaniac View Post
    Had practice at Joe's (Questtek) today and Allen just so happened to showup with a 1450 Mod. Was tuning my P-Sport FE30 for Sunday's race in Camarillo so first I did some laps with a stock S&B H-5; then the 1450. The 1450 (seat of the pants ONLY) ran fine-no *ss hop; a teeny bit slower but me likey ! Will order a few - the "guys" will probably want some too. Thanks for all the input. Oh BTW, I'll give it a try on my Spec FE 30 when time allows.
    Va
    4,670
    I just ordered one myself, it ran much better than the 1640 I had on it.
    IMPBA 20481S D-12
