Results 1 to 5 of 5
Thread: to thrust bearing or not to thrusrt bearing
    Jun 2011
    SD
    287
    Default to thrust bearing or not to thrusrt bearing
    So im running my MG with the 1800kv pro boat motor and a 60A esc have am445 for prop and now im wondering
    should i put a thrust bearing between the collet and motor and if so please list what you are using
    also what order does it go if You use one seems to be a 4 part item and ive never used one.
    Maybe it is a non issue and I dont need what are your thoughts
    Jul 2010
    14
    412
    do you have a video of the boat with that settup ?
    Drammen rock City
    Jun 2011
    SD
    287
    no but ill shoot some this weekend for ya
    Jul 2011
    Va
    152
    www.wohltsrcboats.com they will relieve the pressure on the motors end bell bearing . The one he sells is a perfect fit , you might need one or two 5MM washers depending one the collect your using .
    Jun 2011
    SD
    287
    Finally got out to the lake and had a low wind day here is the vidio you asked for I finally got this one the way i like it without spending alot and 42 is fast enough for fun
    http://www.youtube.com/watch?v=YGguEAWRVi8
    Quote Originally Posted by maxmekker View Post
