Results 1 to 3 of 3
Thread: Water problem
    Apr 2011
    120
    Default Water problem
    I keep getting water in where the servo is I have put new zipties on the rubber where the steering cables are tape everything don't know what else anyone got any ideas
    Sep 2010
    SG
    256
    Corrsion X your servo electronics and apply marine grease on the gears
    Apr 2011
    120
    That's a good idea. I actually found where the water was coming in. The 2 holes up front that hold the cowl on, 1 hole went all the way through I would blow on 1 and hear air come out the servo box. I filled hole up with epoxy and going to redrill
