Results 1 to 2 of 2
Thread: HELP: miss geico not working right after being flipped.
    Aug 2011
    25
    Angry HELP: miss geico not working right after being flipped.
    So i flipped my geico the other day. The canopy and tupperware lid came off. My fault for not taping them down. The bottom half of the boat was submerged for a little over 5 minutes. So after i brought the boat back home i took everything apart and dried everything off it turned back on no problem. So i went back down to the local lake and ran the boat but it started slowing down after about 20 seconds on full throttle. I thought maybe it was the lipos that went but i put a new set in and still the same problem. So i reset the esc thinking that maybe when i disconnected everything the esc reset itself back to factory setting. But i still had the same problem after trying the boat out again. So is my esc messed up? or is my motor messed up? Thanks guys.
    1,431
    how long did you let it dry for?
