Results 1 to 3 of 3
Thread: Pb stiletto outboard efficiency
    Aug 2008
    BH
    340
    Default Pb stiletto outboard efficiency
    Hi Guy's ,
    Just wondering about efficiency of the Proboat Stilleto Outboard compared to Hyper Outboard drive ?? Obviously the PB Outboard has its limitations as far as motor size goes ( 45mm ) . Would like to consider it for my cuurent tunnel project in build section for its scale apprearence , which would be further enhanced by 1980 johnson decal to go with my projects theme ....
    All the best in F/E/R/C Boating ,
    Brad
    Roy Cooper's www.fastonwater.co.uk - Where Brittish Raceboat History Comes To Life !!!
    WA
    8,335
    I don't know if anyone has ever done a direct comparision of the PB Outboard to others in this manner. The PB Outboard may be a little be "draggier" in the water due to mass, but I don't know that for sure. I will, however, put one up against any other as far as driveline drag goes, once you make the updates I've described previously. No loss there!
    Darin E. Jordan - Renton, WA
    Aug 2008
    BH
    340
    Thanks Darin ,
    Seriously considering the PB unit , as i prefer flex drive over geared such as the " EP1 " , have to do some more research on this site regarding them . Should tie in nice with the tunnel project i have going ......
    All the best in F/E R/C Boating ,
    Brad
