After a long day off and many runs of the MG I can report back to those than want to hear
I am running a stock MG motor and esc, I am running a Kinetic offset as of today and I love it! Had most of the wa wa tuned out prior but the offset cleared it all
2-Gens ace 5300mah 2S1P 7.4V 30C Lipo battery packs, 5.5mm bullets on everything motor esc batteries
PB 1.6 x 2.5 SS 27.5 max speed
X642 32.8 max speed
M445 36.8 max speed
All are run with the back of batteries 1.25 inches forward of the rear of stock battery tray
This makes the boat a little light in the front but if I run them all the way forward it is very slow out of the hole
My strut is about 1/8 below the flush level a little lower gives me better take of but we lose out in top speed
I averaged 9.5 minutes run time out of each battery set, this was a all out 9.5 minute run the prop size seemed to make no difference on the total battery time at all
The esc cut out within seconds of each prop
I do not have a temp gauge but nothing seemed overly hot
But after running 3 sets of batteries through with only time to change prop and battery the heat shrink was easy to pull on and off on the esc plugs but able to touch everything
Have 4 Turnigy nano-tech 4500mah 4S 45~90C Lipo Pac and a 447 detonged prop on the way so the next round of test will be done with 4s
Ill add the 447 to the list at the end as unsure if the esc will hold up to the 447 anyone who uses or has used one please reply here with you outcome
