Results 1 to 2 of 2
Thread: Help with prop size...
    Jun 2011
    NJ
    58
    Default Help with prop size...
    Sky-wing 200A Water-Cooled Brushless Motor ESC for RC Boat
    Constand 200amps, max 210amps, Bec 5amps, 2-6s or 6-22.2volt
    with two motor options...
    $69 Tacon 4475-9T Brushless Motor 1600KV for 1/8 Car Buggy Truck
    ROHS/CE Yes
    Watts 2350
    No-load Current /7.4V 3.1A
    Load Current 115A
    No-load RPM 4W
    Load RPM 3w
    Net Weight (g) 543G
    Diameter (mm) 44MM
    Length (mm) 75MM
    Shaft Diameter (mm) 5MM
    or
    $60 Tacon 4465-13T Brushless Motor 1400KV for 1/8 Car Buggy Truck
    ROHS/CE Yes
    Watts 1860
    No-load Current /7.4V 2.4A
    Load Current 88A
    No-load RPM 4W
    Load RPM 3w
    Net Weight (g) 450G
    Diameter (mm) 44MM
    Length (mm) 65MM
    with 2 of these in series for 6s $28 each
    77P-SL3300-3S1P-40C-3333-HardCase
    Capacity: 3300MAH
    Voltage: 11.1V
    Size: 138.21 * 46.56 * 31.38mm (L * W * H)
    Weight: 317.2g
    IR (mohm) 30
    Discharge rate: 40C Continuous, 80C Burst.
    Plug: 4.0 Banana Plug
    I would swap out the 4.0 banana plugs for either 5mm or 6.5mm. But I would get 35k rpm from the first motor and 31k rpm from the second. But the second motor seems to draw less amps. So I think the second option is the better. This is all going in a 32" scorpion. I know I basically have to get a prop and run it to see how it runs, but I am looking to pick up a prop or two to try. So I need to know where to start.
    Mar 2010
    MA
    3,573
    I would go with motor option 2 1400kv if using 6s and prolly start with x445 or m445. Jmo
