Results 1 to 23 of 23
Thread: how would i run 2 4s packs on this boat and still be safe
    Jun 2011
    nc
    146
    Default how would i run 2 4s packs on this boat and still be safe
    i would like to now how to run the 2 4s packs in parallel
    Mar 2010
    MA
    3,573
    Connect the red wire of each battery to the red on the esc. Same goes for black wires. You need to make some connectors
    Sep 2010
    nj
    4,289
    Go to OSE home page, Than to RC boat links, Than at top of page is Tips & INFO , look in batteries tips & info.
    Than go to Q & A SEARCH FOR 5.5 Y connectors or Y deans connectors,
    Go and do search in charger & battery info.
    Jun 2011
    nc
    146
    lenny that link isnt working
    Jun 2011
    nc
    146
    dana so i need to cut the wires and make some connectors
    how is the boat wired now? wire color wise
    Sep 2010
    nj
    4,289
    Sorry
    Look again at posts,
    Jun 2011
    nc
    146
    ok ill try it now
    Jun 2011
    nc
    146
    ok i think i might of figured out my setup
    what do you all think
    proboat impulse 31 deep vee: http://www.proboatmodels.com/Product...ProdID=PRB4250
    castle creations connector: http://www.rcplanet.com/Castle_Creat...11-0006-00.htm
    2 4s 4500 lipos not sure what c rating yet
    Jul 2011
    Al
    134
    Won't doing so destroy the stock electronics? Today I ran two 3S on stock setup and it thermalled after about 3-4 min
    Sep 2010
    nj
    4,289
    Look at my post info.
    You want to go up 5.5, Can you solder to make 5.5 y ?
    Cells 30c or 40c IMP.
    Sep 2010
    nj
    4,289
    You need to run cells in parallel not series or
    Jun 2009
    940
    Jun 2011
    nc
    146
    ok so you guys dont recomemend using the deans connectors
    why do they melt
    Jun 2011
    nc
    146
    what lipos do you recommend
    Sep 2010
    nj
    4,289
    Yes.
    Good lipos, Gens ace or Turnigy 30c to 40c, 3000mah and up, I use soft packs 4s 40c to 50c 5000mah
    Check out the testing hear,https://forums.offshoreelectrics.com/...attery-Testing
    Jun 2009
    940
    For the money Gens ace.
    Sep 2010
    nj
    4,289
    Oct 2008
    9,488
    Quote Originally Posted by arp1500 View Post
    why do they melt
    Deans can take 60amp cont. I think, where as Bullet connectors can take much more amps
    this is what I did to run deans on my SV27 boat running parallel packs
    I soldered the back leads of the connector and placed this on one side of the stock series wiring on the esc
    and these are my parallel connectors for bullet packs
    Jun 2011
    nc
    146
    brushless 55,
    looks good
    is it needed 2 run bullets because everything else i have is set up with deans 5 battery packs, 2 chargers, 4 trucks
    so how is the inside of th eproboats wired..
    would i have to cut off the stock deans and re wire that also or just make a adaptor
    Jun 2011
    nc
    146
    does anyone have a pic of the inside of the boats with the wires exposed
    May 2008
    1,744
    Let me take shot at explaining the series/parallel thing. Forget connectors for just one moment and lets just talk wiring.
    1. Parallel. Take the red wire from battery one and connect it to the red wire coming out of battery 2 and then connect that to the red wire going to the esc. Repeat the same thing for the black side. Now you have two batteries connected parallel. Same voltage, but twice the MAH's.
    2. Series Now this looks weird, but I promise it will not blow up. Plug a red wire out of battery one, into the black wire of battery two. Now, take the red wire from battery one and hook it to the esc, and then take the black wire from the battery two to the esc. You have now doubled the voltage, but same MAH.
    With bullet connectors, one connector per wire comming out of the battery, here is how I hook it up series.
    1. Plug the red wire of battery one into the black wire of battery two.
    2. Plug the red wire of battery two into the esc.
    3. Plug the black wire of battery one into the esc.
    4. Ready to go.
    Might help you picture how it works better...
    Oct 2008
    9,488
    not sure if these pictures will help, but here is a 4s2p setup using 4 2s packs
    Sep 2010
    nj
    4,289
    Wiring diagrams in OSE tips & info,http://www.offshoreelectrics.com/inf...l-parallel.php
