Finally done -- It will hit the water in another 3 hours.
Build thread: https://forums.offshoreelectrics.com/...40-inch-rigger
6S1P 5300 MAH Gens Ace batteries
CC2018 Motors (1800KV) spinning at 40000 RPM
Wire drive with 447 props.
44 inches long, 26 inch wide.
Weighs 13.5 pounds RTR
Finish is clear polyeurothane over plywood.
I hope this thing works? With a homemade hull, homemade turnfin, etc. -- it is highly probable that it will blow off or suck down or something will go wrong.
If the hull works correctly it may go between 80 and 90 MPH.
The no slip speed is 98 MPH
The 15% slip speed is 83 MPH
The 10% slip speed is 88 MPH
Mark
Homemade: turnfin, motor mounts, struts, wire drive, water pick up's.
