Results 1 to 4 of 4
Thread: Need a new prop!
    Jun 2011
    7
    Default Need a new prop!
    I busted my stock prop on my Genesis this weekend and am looking around for a metal replacement.
    I'd like to find a 42mm with 4mm shaft or I can shim up a 3/16 shaft.
    The problem I am running into is everybody is out of stock!
    Any suggestions?
    Thanks!
    -L67
    Nov 2008
    Ql
    3,169
    Depends on what size & kv motor, & what size & type of ESC your supplier fitted to the hull. Different suppliers fit different combinations.
    So, what do you have?
    Regards.
    Paul.
    Jun 2011
    7
    The motor was stock with the Genesis and the ESC is a 125A.
    The prop that came with it was plastic or nylon, 40mm, 4mm shaft. I don't know what the stock pitch was though.
    I heard clearly not to go to a 44mm as it will burn up the ESC, so I'm thinking a 42mm would be ok since I plan to eventually update the motor and esc.
    What I am running into is it seems nobody has any metal props available right now (out of stock).
    Also, I see there there are very few with a 4mm shaft option.
    I read an article on on to shim a 3/16 prop to fit a 4mm shaft and I'm willing to go that route until I upgrade the drive cable.
    Any suggestions?
    Nov 2008
    Ql
    3,169
    You still didn't give us the specs on the motor. Just saying "the stock motor" means nothing, because as I said different suppliers fit different size & Kv rating motors.
    Cheers.
    Paul.
