How many total cells?
Sorry 2s2p
Brappp
4 cell total
Brappp
here is a new video of my Impulse running a octura x445 i think i have her running purty good. but once again my lil girl did the video so sorry
Brappp
My camgirl is only 2 years old so my boat videos are either mostly shots of grass or the sky or both if I'm lucky!
That's how it was when I was little driving the real boat. Trees water trees water trees
Brappp
Now make an octagon! She has a cute finger
Looks like its running a little loose, but she's still moving nicely.
Grand River Marine Modellers
It's 4cell total I guess that's 4s2p I'm still new to the hole boat thing I'm used to cars 2cell and 2cell only :)
Brappp
Do you know what your temps were running the x445? How much faster do you think your boat is now over the stock prop?
I did not run the stock prop as for the temps I don't use a temp gun never have I go by the 10sec rule if you can keep your finger on the motor or esc for 10sec or more your good and I could
Brappp
two 2s packs in series = 4s1p. two 4s packs series = 8s1p.
two 2s packs parallel = 2s2p. two 4s packs parallel = 4s2p
hope this helps
Yes it does thanks
Brappp
Mine won't be on the water until Tuesday assuming my parts get in Monday so can you make some more videos? Maybe let your daughter drive and you video this time?
The only problem with that is I wouldn't have a boat any more. But as soon as I can get a buddy of mine to come out with me I will get a good video of it
Brappp
Awesome, I'm looking forward to it!
well i pulled the trigger and installed a Seaking 180 and a Leopard 4074 2000kv and lets just say this thing just flys literally. I will try and get a video of it up today after i dry it all out from a nasty blow over. I guess i need to do a little setup work before i do full speed runs.
Brappp
It was running really loose the way it was before with more power it's prob all over the place. Can you post some pics? My stuff won't be here till tomorrow.
The seaking is a real tight fit in the stock location
Brappp
As long as it fits though. I ordered some extra caps for mine since my caps always ran a little hot on my old seakings. I figured I was going to have to run them on the battery wires and not like everyone else was installing them because of space limitations if I mounted it near the stock location. Thanks for the quick pics!
What do you recommend me to get it to run a lil less loose?
Brappp
First adjust the CG a little forward and if that doesn't help i'd put a tiny bit of negative angle on the strut back end and fine tune by bringing down the trim tabs. I always try to adjust my boats without going straight to the tabs. You might be able to raise the strut a tiny bit too.
Ya I noticed that the tabs do a lot with a little movement hopefully my receiver is still good and I can try it again today. No I know why a lot of boat guys run a cheaper radio system.
Brappp
Are you taping the hatch? I'm running the gt3b on mine. Let the receiver dry out or if you have corrosion x spray it on and it should be good to go.
No spectrum stuff just glitches not a fan I run all Futaba stuff as hopefully I will soon be sponsored by them for car stuff
Brappp
Nice, I edited post but I agree with you. Lost a couple boats. I noticed you've got your cooling lines going to the motor first. If it was me I'd go to the esc first. It won't look as clean but it'll run cooler.
Yay just bench tested the receiver and it works. I will say one thing this boat is tuff it took some really hard flips and hits with no damage
Brappp
Now go get the camera girl and do some triangles!
Well this is what happens when you don't use a shear bolt
Brappp
