Results 1 to 4 of 4
Thread: what is optimum prop speed?
    Jul 2011
    172
    Default what is optimum prop speed?
    What prop speed do you aim for? I see it can be calculated by KV x battery volts.
    With a:
    3000kV x 7.2 V = 21,600 RPM
    3000kV x 10.8 V=32,400 RPM
    Which is the better choice for a small mono? If you go with the "too high" 3S battery can you just dial down the ESC so it does not go so high?
    1,969
    Quote Originally Posted by Chenige View Post
    With a:
    I like to aim for high 20K or low 30K myself. Note, if you are talking Lipo, then it is 3.7V per cell, so your 3S would be 11.1V. I forgot who originally posted this chart but has come in handy:
    Chief
    Jul 2011
    172
    whoops. 33,300
    And thanks, per the chart 3S is the way to go.
    Apr 2011
    1,759
    yeah, 3S would be the way to go. if you were talking nickel cells, you could use 7S for 8.4V, and get a little more rpm, or try both. some people do run outside that chart, usually slower but I'm running a 1970kv motor on 5S, oops! hehe
