Results 1 to 23 of 23
Thread: 2 (4s) in parallel, will they fit???
    Jun 2011
    Ma
    25
    Default 2 (4s) in parallel, will they fit???
    I have a Miss Geico and dont want to modify the battery trays yet. Will two 4s 5000mah batts fit with no modifications to run parallel?
    Jun 2011
    SD
    287
    yes but its tight and getting out is worse than getting in but they will fit also can stck 2 2s and that fits
    Jul 2010
    14
    412
    I will receive my 2 zippy 4 s 4500 today. will post picks.
    Drammen rock City
    Jul 2010
    14
    412
    here are my 4000 4s zippy. I said 4500, but it was 4000.
    IMG_0085 (Medium).jpgIMG_0084 (Medium).JPGIMG_0083 (Medium).JPGIMG_0081 (Medium).JPG
    Drammen rock City
    Nov 2010
    ca
    254
    i know the nano tech 4000 fit no problem
    Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
    Jun 2011
    Ma
    25
    Thanks for the great pics Max, very helpful. I am gonna try to squeeze some 5000mah in there!
    Jul 2010
    14
    412
    I found it was a tight squeeze to get them in and out because of the side woodwall. Winter projeckt to rip it all out and lower the trays and install another motormount to give more space. Hope to test them today and see if they help with stability.
    Drammen rock City
    Jun 2011
    Ma
    25
    I am inteseted in how the stability worked out with these and what your run times are? I really want to buy 5000mah 40c for max run time. If your saying the 4000mah barely fit in, then 5000mah may be a nightmare. I may just buy em and see what happens, then modify if i realllllly have to. Also cant wait until my Mystic comes in to play around with Miss Geico, HAHA!!!
    Nov 2010
    ca
    254
    i don't know about 5000 4s if they will fit or not i do use 4s 4000 and they can be a real pain to get out if in a hurry, because i used 4s2p i dont have a problem with stability its still very stable and corners very very good
    Jul 2010
    14
    412
    Sorry for the zoomed in. The two other clip's were corrupted,but you get the idea.
    Drammen rock City
    Jun 2011
    Ma
    25
    Very nice Max, thanks for the vid. I have the same setup as you. Just got the m445 prop in the mail a couple days back. What is the approx run time with the 4000mah?
    1,431
    I fit 5000 mah packs in mine 4s2p, I think the 4000's might almost be better though.
    Jun 2011
    Ma
    25
    Shaughnessy, do you have these batteries velcro strapped down or just velcro on battery and tray? What C rating are they? You said 4000's may be better becauase of handling or fitment? Sorry for all the questions!!
    Jun 2011
    NO
    97
    I use two 5000mah in parallel and they fit. Nano techs. But its a squeeze. I broke off one of my battery trays in a flips so I think I´m going to remove the other one also.
    Ørjan.
    Jul 2010
    14
    412
    Both of mine came loose in this flip(at the end on 5s) I think I will ,as a winter projeckt , rip them out and lower them to make it easy to get the lipos in and out. But I like to have them above the bottom og the hull in case of a leak etc.
    Run time, well , I brought it in to have a look at the temps, and the boat was filled with water.No more grease on the flex, so the water came up the flex. I feel like I greas the flex well, and often, but I had to call it last night.so I dunno the runtime.
    I just used velcro on the pack's , but I feel like they might need to be straped down to.
    Drammen rock City
    1,431
    I used to just use velcro, now i have pool noodle to hold them in place along with velcro, straps are a good idea. Couple of bad stuffs has split the front of mine because of loose batts. 4000s for fit and a little lighter, the weight doesn't make a HUGE difference but it's definitely noticeable.
    Jun 2011
    Ma
    25
    Gosh, this hobby is getting expensive, but I love it. Decided on two Nano techs 4500mah 45-90c and some velcro straps from Hobbyking of course, new Kintec flex shaft and offset rudder. To boot, still waiting for my pre-order Mystic to come, but looks like now its late September etc..... which blows. I was planning on running both boats in Meine at my lakehouse in earl Sept. but that aint happening. Whatever, I still love the Geico and still trying to work out the bugs.
    Jul 2010
    14
    412
    I also just had a look at those lipos, ore the 4000 since they were 29mm in hight.
    Drammen rock City
    Apr 2010
    AL
    430
    whats in parallel how you do that
    Jun 2011
    Ma
    25
    Wiring in parallel allows longer run times. In order to do do, a parallel connector needs to be made. Somewhere here on the forums, there is a how to on this with pics.
    Jul 2010
    14
    412
    This is how I charge my battery's. In parallel. NB Always Same brand /cell count and mah. NB
    http://www.youtube.com/watch?v=t8L_c-cFpSQ
    Also when I want to make my 2x 4s 4000 into one 4s 8000mah, I use the parallel wire. That way it's still a 4s (for the esc) but you get longer run times.
    also have a look at this site.
    http://sites.google.com/site/tjinguytech/home
    Drammen rock City
    Jul 2010
    14
    412
    And if you have , let's say , 2x 2s 4000 mah, and want to make that into 1 4s 4000 for you're boat, you make one of this wires.
    Drammen rock City
    Apr 2010
    AL
    430
    Ok cool im going sunday to buy a new mg and was wondering what yall meant but see now thxs bro I greatly appreciate it maxmekker
