Results 1 to 6 of 6
Thread: Miss Geico as submarine and aircraft
    Jul 2010
    14
    412
    Default Miss Geico as submarine and aircraft
    Drammen rock City
    Jul 2010
    14
    412
    there. I did not manage to get it to show in the first post.
    leo 2000kv / 642 prop.saltwater
    Drammen rock City
    ive heard that smacking sound before lol
    Jul 2010
    14
    412
    Second time did not go so well, almost the same place to.
    The best I could do since it was first time with glassfiber. Messy stuff. Nobody will se at wot out in the lake anyway..
    Drammen rock City
    If you can get inside the hull it's best to do it from there. And also lay some fiberglass cloth within the resin to add more strength and get all the air bubbles out. Just laying resin over the crack outside won't hold it long in an accident.
    There are other methods that work too. This is the only one I've done so far.
    Jul 2010
    14
    412
    I know. I used slow curing (24h ore so) epoxy the first day, then I mixed up for some glassf. But it was the autoshop type with to big masks and a hassel to work with on the tight spot. It passed the water test, no leak :-)
    Drammen rock City
