If anyone has the kintec offset rudder v2, may I have a couple pics of it installed so I can see what it looks like?
I ordered one for my MG and want to see if need to do some trimming to make sure larger props clear the mounts.
i have one and if u want to run bigger props and raise the strut up some u will have to trim the bottom corner of the strut brace...its a easy fix with a dremel....u dont have to trim anything on the kentec stuff
I have the one that he is selling on the netshop now is that the v2? I have pics I can upload.
Edit: Here´s the pics anyway, that´s a x642 installed. with 3-4mm of clearance from the bracket.
Ørjan.
I have bent 2 of these brackets. both on drift wood. is there any other options out there?
I would suggest using a plastic bolt on the lowest mounting point on the rudder so the bolt breaks instead of the bracket. you can see it in my pics it worked for me when i hit some drift wood in the ocean :)
Ørjan.
thanks i will try that.
Got mine today installed and trimmed the back off the bracket that hangs over the prop. So I don't have to worry about it hitting with adjustments and larger props.
What do you guys think about using those plastic bolts for both rudder slots?
[QUOTE=JPriami;339191]Got mine today installed and trimmed the back off the bracket that hangs over the prop. So I don't have to worry about it hitting with adjustments and larger props.QUOTE]
That looks like a real clean trim job, and i'd like to do the same. Would you let me know what you used, and/or how you did it? Thanks!
Peacock8,
Where did you get that antenna?
Its partly homemade. The alu mount I bought at OSE, I put a alu spacer underneath it for added support. The tube is evergreen plastics that i painted black.
Ørjan.
