Results 1 to 1 of 1
Thread: Esc issues
    Jan 2009
    WA
    45
    Default Esc issues
    Wonerring if anybody can shed some light on an esc issue.
    Have stock standard Delta Force Sniper 23. the kids accidently entered the program mode and I cannot for the life of me work out what was changed. The esc armes ok, pull the throttle and the motor runs for a couple of seconds and then cuts out. Disconnect the battery and try again, same thing happens. Can someone please assist. I have the esc instructions but cannot fathom what would cause the issue. Tried connecting a new motor and same thing, esc has never been drowned or hot. Great little boat, need to get it running again. Also have a similar issue with an etti 150 esc with my sv 27, where the motor shudders when the trigger is pulled
    Cheers
