Also you don't want the strut all th way up put it on a table with the rudder just hanging off and adjuts the strut flush with the bottom of the hull then from there you can make minor adjustments. My mg sits pretty low in the water but I also lowered my battery trays a good 1/4 to 1/2 inch over stock an I also make sure my batteries are as far to the outside as they can go. You can remove your battery trays very easily then with a dremel just cut the epoxy off I made little blocks to go under them on the insides of the trays so that when I installed new trays they sit flat. My boat sits so much better now that I have to move my batteris all the way back now and it never wants to blow over even at 60+mph
miss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717
