Results 1 to 7 of 7
Thread: 2200 castle motor, what battery should i run?
    Jun 2011
    mi
    113
    Arrow 2200 castle motor, what battery should i run?
    I have a 2200 castle motor with a 180 turnigy esc installed in my mg. I was told to get 6s batteries, is this right? I do have a 440 brass prop also. I went to another local shop today and was told I should only run 4s because the 6s ( 2 3s) would blow the motor, is this true????
    Aug 2009
    tx
    3,534
    I have a couple I wouldn't go over 5s
    Feb 2011
    QL
    203
    you will blow your esc trust me been there done it.
    run it on 4s you will have ample power/speed and some to spare the 2200 castle revs like crazy.
    Feb 2011
    QL
    203
    i have the same set up in my Geico.
    Jun 2011
    mi
    113
    Ok, thanks
    Feb 2011
    QL
    203
    These are the batteries I'm using. But I cut the 5.5 bullet conectors off them and put on traxxas style plugs I don't suggest you do that as it is a tricky thing to do.
    http://www.hobbyking.com/hobbyking/s...dProduct=14691
    Jun 2011
    Fl
    84
    I tried 6s and blew the ESC...now I only use up to 5S even with the new T180
