Results 1 to 7 of 7
Thread: Just made my own water pickup for BJ
    May 2008
    CT
    124
    Default Just made my own water pickup for BJ
    I have had my fullers for some time now so I changed out the rudder to make it off set and took off my steering fins and filled in the last step on the BJ... Since I did not want to cut up my fullers stock rudder assembly I went to the LHS and bought a piece of aluminum tube 5/32" and sqeezed in my vise to make the pickup more oblonged to make less drag in the water... Here is acouple of pictures of what I did....P6223239_edited-1.jpgP6223237_edited-1.jpgP6223238_edited-1.JPGP6223236_edited-1.jpgP6223234_edited-1.jpg
    Joe
    Jan 2011
    WA
    218
    How much did it help to fill your last step in? I've been thinking of doing this myself
    May 2008
    CT
    124
    It made my boat handle so much better. To me it is a must upgrade on the blackjack. And if you do the upgrade take off the turn fins you will not need them anymore.
    Joe
    Jan 2011
    WA
    218
    I see you let the ends run further than the transom. Im assuming this was done for a reason?
    May 2008
    CT
    124
    I did that to see if it will help keep the nose down in quick throttles and to keep the boat my stable on fast runs.
    Joe
    Feb 2012
    30
    what did u use to fill it in? it looks like plastic and how did u attach it?
    May 2008
    CT
    124
    You can get plastic the right thickness at your lhs. I used balsa wood that I had. I used an opoxy based
    Resin. I painted the balsa wood first and then used the two part opoxy to attach to fill in the step.
