Simple question I hope....
I have a charger and am charging 2 Lipo 5000 mah batteries in parallel at 10 amps total. See simple.
My PC supply is lower rated but still states 250 watts. So at 12 Volts, should deliver 250/12 or 20.8333 amps (less efficiency) for charging capacity.
But still voltage is dropping too low so I can only charge at 8 amps total as voltage hovers around 10.65v. Charger is cool, so heat is no issue.
Has anyone actually added a resistor bar or other form of current draw on the 5 Volt bar to increase Voltage? Does this work? Worth doing? Any other suggestions?
Since I just dropped over $300 on batts and charger (Hyperion 720 duo
) I am not buying a power supply....yet! And looking for possibly a simple solution to my simple question...
