Results 1 to 5 of 5
Thread: Lipo Question
    Jun 2011
    3
    Default Lipo Question
    does running 2 lipos in parallel boost the C rating while keeping voltage the same? If I wanted to run two 2s 4000maH 25c lipos in parallel would that make it a 2s 8000mah 50c lipo?
    Jun 2008
    896
    No, the C rating stays constant, however, theoretically you will be able to supply more amps.
    Here's what I mean.....
    2s1p @ 4000mah @ 25C = 100A discharge
    2s2p @ 8000mah @ 25C = 200A discharge
    BUT, that's assuming that the packs are matched very well. Remember, you can now theoretically supply 200A to the system, BUT each of the 2s 4000mah packs is technically still rated at 100A. So if for whatever reason you discharge one of them higher than the other, you can damage the packs.
    Jun 2011
    3
    If I have two Identical packs would that lower the risk?
    Jun 2008
    896
    Quote Originally Posted by AKAxAuto View Post
    to run 2 of them in parallel they have to be the same packs regardless. The c rating and mah have to be the same no matter what. Guys run in parallel all the time. As long as your packs are the same, I wouldn't worry.
    Jun 2011
    3
    Thanks man will do
Tags for this Thread
