Page 2 of 2 FirstFirst 12
Results 31 to 41 of 41
Thread: Go home Turnigy!!!
  1. #31
    Apr 2011
    1,759
    I'll get the 200A and hopefully I don't blow it .
    Not in the mood for working on that boat right now, it needs alot.
  2. #32
    Jul 2011
    Mi
    37
    I also had an 120 cook on me , went with a cc 200 hv very happy.
  3. #33
    Aug 2010
    461
    What boat were you running it in that you went from a 120a ESC to a 200a HV? That's a really drastic difference.
    Light travels faster than sound, so people may appear to be bright until you hear them speak.
  4. #34
    Jul 2010
    544
    3600Kv * 11.1v = 39960 RPMs
    Quote Originally Posted by Boaterguy View Post
    This I did not do, but there was no spark. when the battery was plugged in
    I was running a turnigy 3S 4000mah 40C battery on a 3600KV supervee prop.
    the battery radio and motor I know all were functioning properly.
    the ESC did not heat up too much, that wasn't the problem.
  5. #35
    Nj
    214
    Turnigys suxs. Agreed.
  6. #36
    Jul 2009
    5,669
    9 to date in 2 yrs and 2 have failed. I love them. One, no idea what happen.. just started doin a studder thing.. resoldered everything still did it. The other, totally my fault. 6s on a 180, factory bec.. popped it and next run the esc itself died. Can't blame escs for user error.
  7. #37
    9,400
    The $20 esc deal is a good deal but, in general you are going backwards from Turnigy to SS esc's.
    Fightercat Racing has an excellent esc for $54, 140 amp, small and tough as nails!!!
  8. #38
    Apr 2011
    1,759
    it's on the way
    the setup in this boat has been changed to the FC 2000kv outrunner on 5S. i'm gonna start with a 40 mm prop because I was using SS 200's and they weren't stone cold, i was running a 42.
  9. #39
    9,400
    Well, then, thats a different story since the SS or Suppo esc you have coming was designed to run with outrunners.
    Just make sure you set the timing to at least 22 degrees to 30 degrees to keep it cool.
    If you fo to an inrunner, other esc's are a little better designed..
  10. #40
    Aug 2011
    Ql
    176
    Ive had 2 swordfish 200amp esc' without bec on 6s pushing x447 twins and i have blown two in less than 5 seconds.. no shaft friction, no water, no bec.... I'm thinking they are crap!!
  11. #41
    Apr 2011
    1,759
    i blew three of them in a week
    i asked Ben and he said 8Khz 15 degrees.
    maybe i'll do 23 degrees just because i can
