Results 1 to 5 of 5
Thread: Max motor KV for 3s set-up?
    Jan 2011
    497
    Default Max motor KV for 3s set-up?
    Hi all decided to set-up my 16''' micro hydro on 3s 11.1v lipo . What is the max kv rating i should consider for the brushless motor? Regards Andris Golts.
    Aug 2009
    tx
    3,534
    3200-3500
    Nov 2010
    15
    7
    I am using the motor with 4800kV on 3S. The propeler is Graupner K30.
    Oct 2007
    1,302
    3500-4200 should be the sweet spots. The higher KV you go obviously shorter run times and more heat, and may gain 1-5 RPM but more wear and tear and pull higher amps. You would also will have to use smaller props. It's better to KV down a little and run a larger prop which will give you a nice balance overall, but obviously its up to you.
    Jan 2011
    497
    Thanks to all for the great info. Regards Andris Golts.
