Results 1 to 15 of 15
Thread: Twin mono with non counter rotating prop?
    Jul 2008
    NS
    304
    Default Twin mono with non counter rotating prop?
    Hi guys
    I have couple of cool Etti 1/8 strut that I would like to use to build a twin mono (25-27 inches range).
    My question is whether that would work with the prop rotating in the same direction?
    I have read that there are likely issues with Catamaran because the prop are too far apart. But what about with a mono with the props pretty close? Anybody done that?
    Counter rotating prop is not really an option for me at this stage as I have already bought the flex cable and counter rotating props of that size are very limited.......
    I'm not a racer and the project is just for fun boating with my mates.......
    JC
    Jul 2008
    NS
    304
    Common guys any opinions on the subject?
    I have those hardware that are screaming to be on a twin mono like this one
    http://www.hobbyking.com/hobbyking/s...dProduct=16516
    JC
    Dec 2009
    on
    2,187
    How do you plan on cramming all that stuff including batteries into a boat just a bit over 6 inches wide and still get the CG right?
    Would be cheaper and run better on a single motor.
    Mar 2009
    MI
    6,453
    There is absolutely NO problem running twins in a catamaran.
    I'd think props spinning the same direction in a mono would cause some handling issues.
    May 2008
    Oz
    2,981
    Quote Originally Posted by Rumdog View Post
    ditto.
    make sure your course rotates in a clockwise direction.....
    prop steer !
    Nov 2009
    949
    Did anyone even thing about torque role with x2 props going in the same directions?
    just thinking from what I read on this site
    Apr 2011
    1,759
    two props pushing would create a semi- solid base, and torque roll shouldnt be a problem.
    no rudder would be needed if you were running in a circle.
    Mar 2009
    MI
    6,453
    Quote Originally Posted by Boaterguy View Post
    I hope you're kidding.
    Apr 2011
    1,759
    which part?
    I don't think the torque roll would be as bad as you would imagine.
    May 2008
    Oz
    2,981
    I want 2 Oz of whatever you're on....
    "No torque roll.. creates a semi-solid base ..". you're quoting extracts from setiup sheets for CR props .... a mono will yaw drastically..
    No rudder .. seriously ?
    A long rudder may be the only solution to prop steer and yaw ....
    You can PM re postal for those 2 Oz.
    W
    Dec 2010
    NY
    3,119
    I built a twin gas 56" mono the only problem was a little hopping in the turns other then that no problems there was a vid of it on http://www.oneillbrothers.com/
    May 2008
    Oz
    2,981
    @dasboata.
    Yes, larger hulls display less yaw...
    Due to increased cantilever mass ( the weight spread from side2side compared total mass)
    The application here is to a 25ish" hull.
    Id build it, and budget for a rev cable, and prop for 'ron.
    W
    Jul 2008
    NS
    304
    Now I'm having second thoughts about the twin mono project.....
    I remember there was a guy who did a twin Supervee 27 thread about 2-3 years ago on OSE but I can't find it anymore....... Anybody know how to look for it?
    May 2008
    Oz
    2,981
    Try JesseJ .. that dude twins everything ...
    W
    Apr 2011
    1,759
    Quote Originally Posted by drwayne View Post
    W
    you don't need a rudder because you would be turning constantly with all that yaw.
    2oz of paint thinner, lead fumes, and whatever that stuff was on the floor coming right up
