I agree that the Ammo 2300 is too much motor, it will eventually toast the little Turnigy. Just because you have gotten away with over-amping the ESC does not mean it will last forever. That kind of damage can be cumulative, the ESC will succumb. If you insist on the Ammo motor, stick with an x438 or x440.
The SV27 motor (not the "R" motor I assume) will work in this hull, try an x642 or m545 prop. Actually, the stock 1800 Kv motor is a pretty darn good match for the hull.
