Results 1 to 10 of 10
Thread: 1800kv motor results
    md
    109
    Default 1800kv motor results
    I replaced the 1500kv motor in my Miss Geico and installed the 1800kv stiletto motor. I am also using the SeaKing 180a esc.
    on a 4S set up (50c 5000mah) with a M445 prop it ran 42.5mph. The boat handled great no bounce at all. With the stock motor it ran 41.6mph.
    I am going to do a 5s set up in the morning....
    Watercraft Performance & ATV
    wppracing.com
    Jul 2009
    5,669
    It didnt run hot w/ the M445? Sport running or racing? I ran that set up, hated it and went back the the 1500. My findings were faster and cooler for LSO racing w/ the 1500. Oh and I ran the 642, detonged and cupped. ran just about the same apeed as the 1500 M445, but ran 25 degrees hotter after a 4 min race.
    md
    109
    Tested the boat today with the 1800kv motor, ran 41.1 and was motor was hot. Installed the 1500kv OEM motor and fresh batteries and it ran 41.5 and alot cooler. It also seemed to have more balls out of the hole. I am using the M445 prop and custom offset rudder. With my set up the boat doesnt bounce of at all even with 6s set up (54.1mph).
    So the 1500kv motor stays..............
    wppracing.com
    Jul 2009
    5,669
    Thanks for the update. I'm glad I'm not the only one who thought the same way. Seems like the "mystic 29" needs to stick with the 1500.
    Aug 2010
    ms
    3,024
    i ran the 1800 and the 445 at the nats and got 11.25 laps and it was warm but not hot.....with the 120amp esc... if i still had the 1500 id prob go back to it but this set up is ok with me
    Jul 2009
    5,669
    No idea how ur doin that on that prop ron. Although, I did get scolded when I mentioned the mystic 29 bounced at the nats (who told me that... lol) and was told w video there was none at all. U r gettn old there ronnie ... sure its a m445??
    Aug 2010
    ms
    3,024
    yes it bounced some and its a m445 wich is less pitch then a 642....when it stays upright it hulls booty
    Jul 2009
    5,669
    Apr 2011
    NO
    22
    Quote Originally Posted by wppracing View Post
    What motor and prop an the 6s setup?
    md
    109
    Stock Miss Geico motor , 180a ESC , M445 prop and a custom offset rudder (https://forums.offshoreelectrics.com/...ad.php?t=25857)
    wppracing.com
