Has anyone done this? I'm about to attempt it. Any advice would be appreciated! I'll let you know how it goes..
The correct size hole for a 4mm x .70 thread is 3.3mm, Octura 1/8" bore prop is bored 3.2mm so the tap will be slightly tight when tapping so you need to take care when tapping using good quality high speed steel taps & thread cutting oil. The most difficult thing tapping a prop out is getting the tap running spot on true to the hole, Not always easy with a slightly under size hole either. Martin.
Thanks Martin! Maybe I can find a 3.3mm drill...
You have to be carefull drilling props as their not the easiest thing to hold so care must be taken & keep fingers well clear. Especially when drilling bronze as drills do bite in bronze. Martin.
Yes - I'm looking at my vise and thinking very hard about it now. Perhaps I'll need to make a fixture.
Excellent, Screw it onto shaft or reverse it on the tap & rotate to see if its running true. Martin.
Runs true to my eye, but but better metrics will follow. Did not enlarge the hole - 3.14mm as supplied. On Graupner M4 stubs it is snug, but consistent.
Supported in basic vise and tapped by hand - no mechanical alignment - 60 degree bites at a time, no lube. This is trial #1, of course - I expect to have to improve my methods. If I don't have to - I will call it fantastic luck.
The entire process took about 20 minutes.
Well, it's not very true.
http://www.youtube.com/watch?v=r7_EEgxjF30
Oh, well. Better next time.
that could be from the tip on your tap
that was a haiku! ...
perhaps... but i doubt it. i may try it anyway.
