Results 1 to 5 of 5
Thread: Esc 180 seaking trying to program ?
    Sep 2010
    nj
    4,289
    Default Esc 180 seaking trying to program ?
    Hi all, how the waters ?
    I am trying to program a seaking 180 with a card,
    But not doing to good with that,
    The first time it worked but i had no reverse,
    Next time no control of motor RPMS went nuts !
    Thanks for any help.
    Jan 2010
    VA
    1,218
    can you get a picture of the card you are trying to use?
    Sep 2010
    SG
    256
    be sure your programming card is meant for boats not cars.
    RPMS went nuts upon plugging the batt connectors is because your full throttle is set to neutral.(pistol grip i assume?) Have to reset your throttle range again. hopes this helps
    Sep 2010
    nj
    4,289
    Thanks it did some.
    Yes its for boats, and yes pistol grip tacic ttx-240.
    I reset throttle range and its working,
    But very touchy throttle forward and reverse, Tried trimming it out, but not much headway with
    the Tx Tactic trim.
    Jul 2010
    14
    412
    look at last post here:
    https://forums.offshoreelectrics.com/...ad.php?t=25756
    is it this card ?
