Page 2 of 2 FirstFirst 12
Results 31 to 38 of 38
Thread: 15"Offshore Warrior mono further mods+ short run
  1. #31
    Apr 2012
    lo
    29
    will this fit to original prop tube and in the hull
    http://rover.ebay.com/rover/1/710-53...ht_4406wt_1043
  2. #32
    Apr 2012
    lo
    29
  3. #33
    Aug 2010
    uk
    2,887
    Are you going to use 2s or 3s as 3800kv on 3s is a hot set up & should only be used for short speed runs as its doing 42000rpm unloaded. I would use a watercooled esc at these speeds as things get quite hot.
  4. #34
    Apr 2012
    lo
    29
    i have no idea any help and info would be good i use 2200ma 3s lipos and was just going to use the motor and speed controller as they come
    cheers
  5. #35
    Apr 2012
    lo
    29
    martin could u put a pic up of your trim tabs fitted and where u got them from cheers
  6. #36
    Aug 2010
    uk
    2,887
    I dont have any pics but the trim tabs are the ones in OSE store ose80069 for $7.95, I cut them smaller to 25mm wide x 30mm length.
  7. #37
    Aug 2010
    uk
    2,887
    The inside edge of each tab is 12- 13mm from the centre of the hull so around 25 - 26mm between the 2 inner edges of the tabs. Their also around 1.5mm up from the bottom of the hull ( dont set them level with the bottom of the hull ).
  8. #38
    Apr 2012
    lo
    29
    thanks for advice has any one got any pics so i dont mess up fitting them
    cheers
