Results 1 to 2 of 2
Thread: leopard 4074 and seaking 180
    Default leopard 4074 and seaking 180
    what timing to leopard and 180 Seaking esc.
    My priority is battery life
    Feb 2011
    AB
    775
    It will run fine at factory default setting of 15* timing advance.
    You will have to experiment with other timing advance settings to determine if there is any advantage in performance and/or longer run time.
    General rule of thumb is lower timing advances draw less amps, but every component combination and setup is different, so the only way to know for certain is to try for yourself.
    Kevin
