Results 1 to 8 of 8
Thread: 6s power!!!
    May 2011
    NY
    36
    Default 6s power!!!
    Ok Im really itching to use my MA 6000xls in my p1 I have 2x 6000MAH 3s lipos to run in series...
    I know the stock motor cant handle 6s so wold this work as a direct replacement???
    http://www.hobbyking.com/hobbyking/s...dproduct=11181
    If not Im gonna replace the motor mount with a water cooled one and use a CC 2200 in runner with more water cooling....
    The ESC can supposedly handle 6s??? but I will replace it with a seaking 180 or a cc marine esc not sure yet...
    I hope the rest of the drive train will hold up...
    Oct 2009
    UK
    742
    Yes it will fit straigt in the stock clamp. Read my thread on this as I had the same motor on 5s with a 90a esc. It was awesome on 5s. Just don't tighten the clamp up to tight.
    https://forums.offshoreelectrics.com/...ad.php?t=19203
    May 2011
    NY
    36
    Quote Originally Posted by jamespl View Post
    I ordered that Motor Im gonna get a turnigy 180 amp esc Im just not sure if its a BEC???
    any one have any experience with the CC 36v esc I was thinking about getting one but for $300 minus $50 for super savers its alot of $$$ Im pretty set on the Turnigy 180 amp....
    Oct 2009
    NC
    4,204
    I ran those motors on a twin cat on 6s great bang for the buck. In a single motor boat though that's a little on the high side unloaded rpm wise. The stock Venom Marine Pro esc is nothing but a over-priced seaking with venom decals. The stock outrunner that comes with the P1 is the same motor you are about to buy from HK with just a higher kv rating and venoms clamp motor mount on the front. They are both suppo motors, I don't like the suppo esc's but I do like the suppo outrunners a lot. Your going to run into the same problem with the seaking 180 as the seaking 60amp you currently have, both are rated 2s-6s. Me myself I never like running esc's to the max voltage. I would suggest run 5s. with that seaking 180 or grab the seaking 80hv esc, which is what i used.
    - Diesel's Youtube
    - Diesel's Fleet
    Jul 2010
    ON
    544
    Quote Originally Posted by Diesel6401 View Post
    I ran the same outrunner in my single apparition and it was definitely too much for the little guy, twin would be ok.
    I suggest getting a T600 1400Kv, but it might not fit in you motor mount.
    Oct 2009
    NC
    4,204
    Quote Originally Posted by GP73 View Post
    T600 maybe to much torque for this mono. This hull is really REALLY narrow, I have a CC1518 in my P1, but have yet to run it. Haven't had the time. I have a really small prop on it, a prather s215 s&b and detongued. This motor should have ice coming from it with this light of a setup lol... I had this motor sitting spare for a long time with no home, so I figured what the hell and stuck it in this P1 i picked up from the swap shop, i think it's pretty much overkill in this hull lol....
    http://i1238.photobucket.com/albums/...g?t=1304048735
    - Diesel's Youtube
    - Diesel's Fleet
    Jul 2010
    ON
    544
    Nah, looks perfectly at home in there!
    May 2011
    NY
    36
    Its def looks perfect
