Results 1 to 4 of 4
Thread: Best Prop advice please
    Feb 2011
    AL
    11
    Default Best Prop advice please
    Ok I have now kitted out my boat and the set up is this:
    1.1 meter Hobbyking Vanquish hull
    Leopard 4082 -1500KV
    Turnigy 180A Marine ESC
    2 x 3S 5000Mah Turnigy in series
    The only question is on the prop. The boat goes well on a Octura X442 but not well on a X440 or X447.
    Any suggestions as to what the best prop would be?
    Thanks!
    Greg
    Nov 2010
    GE
    95
    Hi Greg,
    Try M445 Octura and M540 Octura.
    Feb 2011
    AL
    11
    thanks. I get a little bit of chine walk. Do you know what causes this?
    Nov 2010
    GE
    95
    Hi Greg,
    Is it possible you have too much weight on the left to counter propellor torque effect? I would suggest to first try the M-series of Octura (especially designed for electric boats, as they are a development of the X-series of Octura. Though, Octura removed the ears!). Probably you don't have to change anything in your setup. Otherwise, maybe place the weight of your LiPos only a little bit to right.
