Results 1 to 9 of 9
Thread: Esc and motor??
    Jun 2010
    oh
    42
    Post Esc and motor??
    Want to upgrade my boat what's a good esc and motor to run in my fastech??Oh it's brushless now. Want to stay with brushless
    May 2009
    3,180
    If it's brushless now, what motor do you have now in it and what EsC?
    Was it converted from nitro maybe?
    DJI Drone Pilot
    Canada
    Jun 2010
    oh
    42
    Yes it's brushless now. Came stock with brushless. It's all stock haven't did any thang to it.
    May 2009
    3,180
    The best motor for this boat is this one:
    http://www.horizonhobby.com/Products...ProdID=PRB3310
    The best ESC for this boat is this one:
    http://www.horizonhobby.com/Products...ProdID=PRB3309
    ..and this is one of the best set ups out there, do not change it!
    If you need to go faster use 2 x 2S 5000mAh or larger, 30-40C lipos and x645 prop.
    If you willing to start playing arround with more voltage and larger props use 120Amp ESC with stock motor. remember, you have one of the most popular motor fot this kind of application out there and it will work fine with little higher voltage if you decide to go that way..
    Quote Originally Posted by moore4x4 View Post
    DJI Drone Pilot
    Canada
    Jun 2010
    oh
    42
    Thanks I got some 6000 lipos for it today to try. Going to look for the prop now. Thanks for all the info.
    Jun 2010
    oh
    42
    What do I need to adjust to get the nose out of the water. Trim tabs or out drive??
    Jun 2010
    bc
    6
    Default best motor
    run ul1 esc and motor 2015kv i think,on 4s.stock stilletto prop,41-44mph,things insane
    May 2009
    3,180
    Do you have a video with GPS that you can post here for us to see?
    Quote Originally Posted by 3rcman View Post
    DJI Drone Pilot
    Canada
    Jul 2012
    ab
    19
    I had my stock impulse 31 motor and esc lying around so I threw them in. It soom to go great don't have gps speeds but the 1800kv is a noticeable difference for the better.
