Results 1 to 6 of 6
Thread: Accucel 6
    Apr 2011
    1,759
    Default Accucel 6
    I have an accucel 6, and it is rated at 11-18 v, max 6A. one of my computer adapters is 14v, but the connector is too big, can I run it on my 18.5V one? or is that pushing it? also, what is the amperage of a car batt?
    Apr 2011
    1,759
    Also, do I balance a 4000mah battery at 4A? just as I would be charging it?
    Jan 2010
    2,498
    Im not a big time electrics guy but i ballance charge my 5000's at 5a, then the ac6 will lower the power as it charges, or mine does.
    Nov 2007
    6,927
    Not sure I'd push that many volts into that charger!
    Mini Cat Racing USA
    www.minicatracingusa.com
    Nov 2007
    6,927
    You can get a great deal on power supplies here. Best deal going! Get one of his and add your own connectors. I have two of his 47A supplies wired in series for 24V to drive my Hyperion 720 duo. With 24V you can charge two big packs simultaneously.
    http://www.feathermerchantrc.com/
    Mini Cat Racing USA
    Apr 2011
    1,759
    so 18.5 is too much? i can probably get a connector and just solder up the adapter cord.
