Results 1 to 25 of 25
Thread: 4s (38.1mph) and 6s (54.7mph) video
    Mar 2011
    md
    109
    Default 4s (38.1mph) and 6s (54.7mph) video
    Aug 2010
    ms
    3,024
    get ya a ul-1 motor and with 4s u can get it up to 47...no telling what orbital condition u can get with 6s
    Mar 2011
    id
    85
    do you mind telling me what kv motor your running man that thing is flying on 6c
    washed up factory racers edge driver.. past LHS owner now im back to the hobby I love
    Mar 2011
    md
    109
    Stock OEM motor
    Mar 2011
    CA
    1,431
    Quote Originally Posted by ron1950 View Post
    a ul1 motor on 6s would let some magic smoke out. 46000+ rpm would reck something for sure.
    Dec 2010
    mi
    11
    what kind of temps were you geting on the motor and controler and what prop im geting ready to run a set up kind of like that ( when i get more time) lol
    Mar 2011
    md
    109
    Here is the 6s set up:
    1. 6s with (2)11.1v 40c 5000mah and 7.4v 40c 5000mah hard case lipos
    2. Stock OEM Motor
    3. Sea King 180a ESC ( settings 1-forward, 2- 5 cell, 3- 3.4v low voltage cutoff, 4- 11.25 timing )
    4. 1600mah Receiver Pack (BEC removed)
    5. Relocated Water Outlet
    6. Kintec Offset Rudder Bracket
    7. 4mm water line
    8. M445 Prop
    9. Trued Hull, Fiberglass Sheet reinforced Canopy, Front part of hull filled with spray foam.
    10. Total Boat Weight as listed 6.4lbs
    Motor Temp was 110deg
    ESC was 89deg
    Jul 2009
    5,669
    Very nice wp. You can do quite a bit of tweaking and get a bit more out of 4S. Stock motor Im at 44mph. Im running 4 minute LSO heats and its doing pretty well temperature wise. the motor wires are the only things really suffering. But Im really happy with it.
    Jul 2009
    5,669
    We posted at the same time. You defintiely have something wrong if your only turning 38 mph on an M445. Be sure youve calibrated your throttle on your 180. Deisel was having an issue w/ his Pursuit in it not running like everyone elses w/ the same set up. He found that even though he calibrated, it didnt calibrate correctly. He did it again and picked up quite a few mph. You may be able to get closer to the 60 mark?!?
    WA
    8,335
    Put the right prop on it, and you can do that with the stock motor...
    Darin E. Jordan - Renton, WA
    Mar 2011
    md
    109
    Quote Originally Posted by tiqueman View Post
    On 4s it runs 40.4 mph with a 42/55 I never ran the M445 on 4s and only had a video of the X642 4s set up.
    Aug 2010
    ms
    3,024
    i never recomended the 6s set up with the ul-1 just 4s...
    Feb 2011
    BC
    32
    Quote Originally Posted by Darin Jordan View Post
    Here is my setup and tests. Where do I go from here?
    Initial setup Stock MG out of the box 4000mah 25c (x2) batteries in the middle of the trays = 30.1 mph aggressive bounce.
    Adjusted the stuffing tube to table top level, placed batteries forward of 9” COG line = 31.4 mph almost no bounce.
    In all subsequent tests best speed and performance was with the batteries forward of the 9” line.
    Prop selection and best speeds are as follows: (this is the order tested as well)
    PB 1.6x2.5 composite Stock 30.1 mph
    PB 1.6x2.5 composite sharpened and cleaned up 31.4 mph
    PB 1.9x3.0 composite filed to 45mm dia & sharpened 39.1 mph
    GR 42x55 balanced & sharpened 37.7 mph
    Octura M445 balanced, sharpened & thinned 39.3 mph
    How big a prop can the stock set up handle. I have an old X452 that I plan on modifying. Grinding down the dia & maybe de-tongue it somewhat or a lot.
    Any help would be appreciated.
    May 2011
    FR
    2
    Default MG drive setting...
    Hello everybody,
    I also have an MG (initial setup stock) , and i have some questions about the settings...
    when you say "Adjusted the stuffing tube to table top level" that's mean that you remove the prop and the rudder, then you put the boat on a flat table, the bottom of the drive is at the same level than the bottom of the sponsons ? ( green line is same as red line )
    Isn't there any negative or positive angle of the drive ? I made a little sketch ...
    ( sorry for my english i'm french )
    Thanks for your help
    Mar 2011
    md
    109
    Loosen the strut bolt and set the boat on a table with the rudder hanging off it. The strut will now sit level with the hull.
    Watercraft Performance & ATV
    wppracing.com
  16. #16
    Jul 2010
    14
    412
    Nice run, and no bounce to. 6s in fun, but I got to tame my MG first.
    http://www.youtube.com/watch?v=gqD0K...el_video_title
    Here is mine with the kintec rudder,and all sorts of lipo placements and strutt adjustments.
    http://www.youtube.com/watch?v=Pd0rE...el_video_title
    I had a look at you're site, and will try the settings in the 'RC BOAT MODIFICATION SECTION' . I will try to se If I an copy those( eventhough I think I have been there when testing in the video) and se if that helps. Going to try with the 642 tonight.
    Drammen rock City
  17. #17
    May 2011
    FR
    2
    Quote Originally Posted by wppracing View Post
    Ok that's mean that according my sketch, the red line and the green line are at same level, without angle between them ? ( to insist but i want to be sure to understand well )
    Thanks again !
  18. #18
    May 2011
    NO
    15
    Quote Originally Posted by nycow View Post
    Thanks again !
    I put som weight on the back of the boat to hold it down, then adj. so there was app. the same angel. Tune from there according to the handling of the boat - hope this helps :)
  19. #19
    Jan 2011
    MI
    222
    Quote Originally Posted by BugFreak View Post
    How much weight are you using in the back?
  20. #20
    May 2011
    NO
    15
    Quote Originally Posted by d.a.v.e View Post
    Not much.. just to keep it flat to the table..
    you can hold it down with your arm as well, if you can reach the strut and adjust at the same time.. :)
  21. #21
    Jan 2011
    MI
    222
    Guess I miss read it thought you were actually adding weight to the boat somehow
  22. #22
    Apr 2011
    NO
    22
    Why are you using a separate 1600mah Receiver Pack in stead of BEC power?
  23. #23
    Jul 2009
    5,669
  24. #24
    Jan 2011
    MI
    222
    Less stress on the esc since he's running at max voltage (6S)
    Dumb question by why are folks using an additional battery pack instead of an external castle type BEC? Seems like it would be one less thing to worry about charging?
  25. #25
    Jul 2010
    14
    412
    nhaa, that 1600 hump last's forever. I put back about 400-500 mah after a week+ running.
    Drammen rock City
