Page 1 of 2 12 LastLast
Results 1 to 30 of 46
Thread: Taming my brushless Mini V
    Dec 2010
    348
    Default Taming my brushless Mini V
    I know many here have "been there done that" but I recently got a brushless Mini V from the swap shop here, It has a 380 size 3100 kv motor, seaking 35 esc and 3s 1000mah batteries. I added a water pickup on the transom just left of the driveshaft to cool the esc. For now I am using the stock outdrive and prop. It also has 3/4"w X 1-1/2"l trim tabs.
    When I run it I can't give it any throttle beyond about 1/2. Even at steady 1/2 throttle it has a ton of list to the right. If I crack the throttle at any speed it flips. (clockwise).
    I'm gathering parts to go to .098 flex and strut and rudder system.
    Any ideas to get me more driveability until I can make the conversion?
    I've done a couple of searches but didn't find a magic bullet.
    Thanks in advance for the help.
    Greg
    Sorry for the long post
    Jul 2010
    bc
    166
    try 2 cell
    :canada
    Aug 2010
    uk
    2,887
    Do you know what hull it is & what size is it, Is it sub surface drive & what props are you using. Martin.
    Aug 2010
    uk
    2,887
    Just realized its a surface drive as you stated you added a water pick up to one side of the shaft. Martin.
    Dec 2010
    348
    Sorry
    It's a Proboat Mini V. About 14".
    All I have right now is 3 cell batteries.
    Greg
    Oct 2007
    New York
    17
    3100 kv is very high. Chances are that could be attributimg to your problems. With mine i have a 2700kv on 3 cell and even then it starts to get a little bit hairy as higher speeds. The .098 flex cable conversion should help because it will give you a greater selection of props to choose from.
    Aug 2010
    uk
    2,887
    Sounds like the motor has been replaced with to powerfull motor, Arnt the original fitted with a 3000kv to run on 7.4v. Martin.
    Oct 2007
    New York
    17
    Originally it comes with a brushed motor. The stock esc can handle the 7.4v lipo, but the outdrive normally melts the u-joints when you hook up a 3s lipo.
    Aug 2010
    uk
    2,887
    A 380 brushless motor on 3s is way to much on this size boat. Martin.
    Dec 2010
    348
    I figured it was probably way too much motor.
    Hopefully I'll get to order a 2 cell battery and some small props when payday rolls around.
    Thanks fpr the input
    Greg
    Dec 2010
    348
    Quote Originally Posted by TomM View Post
    Tom what prop are you running on yours?
    Greg
    Oct 2007
    New York
    17
    I run a x430. Temps are very mild. Never has a problem at all, i could prop it up a little bit, but then I'd be risking torque rolling
    Dec 2010
    348
    I probably should go with a X427 since I have 3100 kv to contend with.
    I can always prop up.
    I just want to get up into the correct rev range.
    Greg
    Oct 2007
    New York
    17
    Anything under around 27,000 would be okay. Just watch temperatures and torque roll. Be gentle, its a small boat and requires finess to drive
    Dec 2010
    348
    Yeah torque roll has been my nemesis with this boat.
    It'll all fall in to place.
    The fun is in the process.
    thanks
    Greg
    Aug 2010
    461
    Make sure the prop is sharpened and balanced well, that will help with torque roll a bit too. You could also shift your battery to the left to help fight it rolling right.
    Dec 2010
    348
    Today I converted the boat to a .098 flex drive and added an X427 prop.
    Saturday will be my first opportunity to test it out. I'll post my results
    Greg
    Dec 2010
    348
    Tried to make a run today but the wind was howling and made fit pretty choppy.
    I'll try another day
    Greg
    Jul 2010
    PA
    238
    A steerable outdrive with no u-joint?
    53
    Quote Originally Posted by Pete32200 View Post
    Thats what i was just looking at.....
    Dec 2010
    348
    It has a .098 flex shaft now. No U-Joint at either end.
    Jun 2011
    Qc
    59
    Anyone got a part list to upgrade to Brushless ?
    i got a stock mini-V and i wanna go Brushless ...
    Shoul i upgrade or get aquacraft mini mono or Proboat impulse (small one) ?
    Thanks for the help in advance =D
    Dec 2010
    348
    I'm anxiously awaiting the Minimono
    Right now in my Mini V I am using a 3100kv 380 sized motor
    .098 flex shaft to 1/8 stub shaft
    1/8 to .098 motor coupler
    X427 prop
    All of the above can be purchased here at OSE.
    35A Seaking ESC
    11.1 volt 1000 mah lipo.
    This set up is too much for the mini V hull but it's what I have. Very challenging to drive.
    2 cell lipo or lower kv motor would make more sense.
    IMO the hull is not really up to high speed brushless use. Too short and narrow. I've flipped it with just the throttle.
    I think a hull about 18" would be ideal for the gear I have.
    I will say I really have a lot of fun with my Mini V. Certainly not boring.
    Hope this helps you
    Greg
    Jun 2011
    Qc
    59
    How much did it cost to build it?
    Dec 2010
    348
    Including the boat (bought here in the swap shop) I'm in it about 125 minus batteries. I was lucky, mine was already set up and had a BL moter and a standard servo. I changed the ESC, added the water cooling and changed to flex drive and smaller prop. The brushless motor with the stock prop had wicked torque roll.
    You can do it in stages,
    1 Motor and ESC and add the water cooling. +/- 75.00 depending on motor.
    2 Flex, coupler and prop. 30.00
    Watch the swap shop for used stuff and you may save some dough.
    Have fun
    Greg
    Jun 2011
    Qc
    59
    okay but,
    Do the stock Tx,Rx can be used ?
    Thanks =3
    Dec 2010
    348
    Unfortunately no
    The stock Rx is combined with the brushed ESC. Also the stock servo is 4 wire.
    Jun 2011
    Qc
    59
    okay
    Dec 2010
    348
    Don't be discouraged
    Half the fun for me is finding the stuff you need to assemble your project into something unique.
    It just doesn't always happen instantly unless you are buying new.
    Greg
    Jun 2011
    Qc
    59
    i will try to use futaba Tx&Rx i found somewhere at 39$ ... Cant remember where but i will find it back or maybe the tactic from aquacraft and use your build :)
