Results 1 to 13 of 13
Thread: electric conversion
    Jan 2008
    3
    Default electric conversion
    I have an old Kyosho Jet Stream 1000 about 40" long and I dont know what the weight is but its a plastic hull deep vee boat. I want to put an electric motor in it so I dont have to deal with the nitro mess and tuning anymore. I am into electric planes also so I know a little about brushless motors and lipos but I think boats are a lot different, from what I read anyway.
    Could someone help me with how to size a motor and speed control to fit this boat? Ive found a couple web sites that sell boat equipment but I am just more confused. I would like to get about 30-35 mph out of it like the nitro motor.
    This is kind of what I have figured in my reasearch, I will need:
    80-100 esc??
    Dont know how to size motor???
    3000-4000 20c lipo??
    Am I going in the right direction?
    Any help would be great.
    J
    Nov 2007
    1,280
    you will need big $$ stuff for a 40" hull check out the build section for a boat that size
    good luck with it.
    1,711
    KB 45 9XL motor (1400kv) water cool it
    4S1p 5000mah 25 -30C lipo
    120 amp 6S controller
    M545 prop
    80 amps
    30 -35 mph
    20,000 rpm
    3.75 minute full discharge
    Lipo 80% discharge is 3 minute run time
    KB45 10XL (1200kv) water cool it
    6S1p 5000 mah 25-30C lipo
    120 amp 6S-7S controller
    X445 prop
    85 amps
    35-40 mph
    25000 rpm
    3.5 minute full discharge time
    Lipo 80% discharge is 2.8 minute run time
    ReddyWatts fleet photo
    Nov 2007
    1,280
    <4 minutes that sucks
    Nj
    4,735
    Thats avarage for a fast boat. Lets not scare away the newb just yet . I know Kyosho hulls. This one is carries just a little more weight but is much more rigid than a Super Hawaii, which is about the same size. Reddy has the setup nailed as always. You can also run a set of 36mm 1800 to 2000kv L size motors. Two 100amp esc's on 4s-1p. 37 to 38mm props for around 70 to 80 amps. Run times around 5 minutes. My 2 cents anyway.
    Nov 2007
    1,280
    I never really timed myself but it seems like I run longer than 4 mins
    I'll have to bring a stop watch next time I run.
    Nj
    4,735
    I can probably run 5 to 8 munites but thats running the packs to deep and risking damage. I need the stop watch & do the math my self. I have been getting carried away latley.
    Jan 2008
    3
    OK with all of this said. I would like about 8-10 minutes run time. Is there a brushed setup that could do what im asking. Maybe a double brushed setup?
    Reddy,
    I like the setup you gave me... but very pricey.....I would be better off with a new hull and electrics probably. Can you figure best brushed setup that you might know of. Maybe I could drop speed a little for a little more runtime???
    Thanks so far you guys have given good ideas.
    J
    Nj
    4,735
    You can drop the 9xl to a 10 or 11 parallel a set of 4s 5000mah packs, srub off a few MPH and pick up or get very close to the run time you are looking for. It is a little pricy but large hulls always are. The advantage of being able to run in more water conditions is well worth it IMO.
    1,711
    This brushed setup can be run on 12 cells at 35 amps for 6 minutes on the 4s1p 5000mah It will run in the lower 20's in your 40 inch hull.
    http://www.offshoreelectrics.com/pro...prod=ose-700sc
    http://www.offshoreelectrics.com/pro...prod=hl-je600n
    This is another brushless setup you can run on 12 cells at 35 amps for 6 minutes of run time on 4s1p lipos. Will probably run mid 20's.
    http://www.offshoreelectrics.com/pro...qug7000&cat=42
    http://www.offshoreelectrics.com/pro...prb3309&cat=75
    Water cool motor and controller on both setups. The longer you run the hotter they will get.
    *You can purchase a SV27 RTR boat and it will run with your nitro for a reasonable price.*
    It will have a 5-8 minute run time depending on which batteries you purchase.
    http://www.offshoreelectrics.com/products.php?cat=52
    Jan 2008
    3
    After searching this site and others it looks like I can do this upgrade for about $120-130 dollars plus the cost of a battery.
    Which motor is better? Aquacraft? Ferigo? Hextronic?
    Also, This boat is a single prop, would it be better to run 2 motors through some sort of gearbox? on a single battery? or double battery? I havent seen any type of gearboxes on any of the site. What are my options there? Any info would be great.
    Thanks for all the help.
    J
    Jan 2008
    singapore
    55
    Quote Originally Posted by wildjaych View Post
    J
    my bet be the feigao ,,, but it really depends how u gonna set it up at the end of the day , what kinda lipos and props???
    Aug 2007
    693
    There is not enough room in this hull to worry about 2 motors
    1 bigger motor and esc is better than 2 smaller motors and 2 esc's (and cheaper)
