Results 1 to 4 of 4
Thread: 21/40 stinger drive unit...
    Apr 2011
    Ct
    240
    Talking 21/40 stinger drive unit...
    So I had this drive that I ordered from ose and never put it on... Going to put it on my Spartan and my question is after it's all on, should I leave it level with the hull or have it pitched up slightly? Now I'm gonna be running 4 3s lipos i'n series parallel and will be able to use 2 3s lipos by just unplugging the harness me and my father are making.... Thanks i'n advance fir any info!
    Feb 2011
    AB
    775
    I'd start with level, then play around with a bit of positive or negative pitch to see what works best and gives you the results you are looking for.
    Kevin
    Apr 2011
    Ct
    240
    Ok sounds good that's what I thought I was gonna hear... That's good tho . Just wasn't sure if there was a rule of thumb for adjusting those ... Trial & error I guess... Lol thanks!
    Oct 2008
    CO
    9,488
    Quote Originally Posted by Rcforever27 View Post
    it's the best way!
    if you start out more neutral and take things easy you should be just fine then start making very small adjustments tell you find that sweet spot
