Results 1 to 9 of 9
Thread: Swordfish 240hv Programming
    Jan 2011
    597
    Default Swordfish 240hv Programming
    this is my first swordy esc, Running cc1717, 6s2p, x646 prop, 35" DF mono. Can anyone tell me what my setting should be? I have the program box, just dont know what some of the things mean, like the pwn??
    Jan 2011
    597
    well it doesn't seam that this program box even works?? wtf
    4,204
    Quote Originally Posted by 6sHyper View Post
    Which box are you using the square one or the small tiny card.
    - Diesel's Youtube
    - Diesel's Fleet
    May 2008
    Oz
    2,981
    what are you doing (wrong) ?
    Id set
    pwm 8
    timing medium
    lvc as per your batts .. and that's it !
    Jan 2011
    597
    4,204
    You have to plug in the esc to the box, add a rx pack to power the box and plug in your lipos to power the esc.
    The setting dr.wayne said will be perfect
    - Diesel's Youtube
    - Diesel's Fleet
    Jan 2011
    597
    It wouldn't read the esc, i tried like 10 times, so i decided to make you guys a video to show you exactly what it was doing and i'm literally filming it and when i plug in the 6v battery it friggin shows up as swordfish 240 and i programmed everything in! LOL.
    I did as drwayne said, and for the other things i did soft cutoff, standard start, soft brake, i think that was it.
    May 2009
    3,180
    So you got it right?
    Get the USB linker.
    I have this ESC and with the USB linker it is easier than Castle ( well still have no data logger but the new version of it will have it )
    Robert
    DJI Drone Advanced Pilot
    Canada
    Jan 2011
    597
    yes got it the Box worked like a charm once it finally recognized the esc! my run was a total nightmare though, but thats another topic, literally. check the build section, this esc might just be toast now after being submerged for 30mins.
