Results 1 to 11 of 11
Thread: SeaKing 180 and P Mono
    ma
    8,693
    Default SeaKing 180 and P Mono
    I normally dont push my setups hard because we dont race much, so I'm looking to gauge whether or not I can use seaking 180 with a p mono setup.
    Boat is a delta pirate knockoff with a 4082 2200kv motor.
    Steven Vaccaro
    Mar 2008
    974
    Steven, I use my 180 with a Neu 1527 1D on 4s and 6s. I finally burnt it up on 6s and a saw set up so 4s is no problem. I think these are strong contollers for the money.
    Mark
    ca
    6,963
    Steven, Hi !!
    I run the Seaking 180 on my Insane 34" P-Mono setup with a Neu 1521 1.5D
    (1900KV) spinning a 450/3 mildly tweaked by Mr. Sholund. The boat weighs 9.5 lbs rtr. After @ 2.5 min the motor is barely warm, the T180 is maybe 120 deg & the Etti cap board is @ 130. Mark F has run the same setup before with a 1527 on 4S with no probs with the SC (other than setting the LVC to "NO LVC" and cell count to autodetect) I have no hands-on with the 4082, but the T180 has proven rather nice on 4S- I even use the built-in bec.
    9,402
    I run the 180 in my DF33 P-mono. I use a 1521 1.5D and a CMDI 5083 x3blade prop.
    Sheyaaa! it hauls. The prop is really high compared to other P-mono's.
    The caps get hot and I'm going to add more before I take her out again.
    My temps are similar to above post by PropChopper.,
    US
    5,557
    I run a T180 in my 39" DF knockoff(Vader) with a 1717 on 6s with an x447...........no problems. Had to prop down from x450 as weather warmed up.
    Oct 2008
    9,488
    These speedos sound like tanks!
    Va
    4,670
    I run a T-180/etti cap bank in my P-mono with 1515 1Y. Did great last season.
    IMPBA 20481S D-12
    Dec 2008
    Vi
    409
    Been running 4082 1500kv on 6s in a DF33 & X648 for well over 6 months , with not a problem , i LOVE these ESCs , good bang for your buck , oh i had the BEC disconnected since new . Did fit extra caps , and a cooling mod .
    UL1- 1515 castle/neu / 240 swordfish
    SV27- with UL1 running gear
    33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
    ma
    8,693
    Thanks for all the info guys. I added some caps like you did Scoota. It seems the easiest and cleanest way to do it.
    Steven Vaccaro
    Jan 2009
    ok
    914
    What size caps did you use in those pics scoota? Steve do you have the caps?
    ma
    8,693
    Steven Vaccaro
