Results 1 to 6 of 6
Thread: Stiletto Battery and Charger Help
    May 2011
    OH
    5
    Default Stiletto Battery and Charger Help
    I recently decided to get into boats and bought a Pro Boat Stiletto and I am a newbie. These are the recommended batteries
    • DYN5351D 7.4V 3200mAh 25C Li-Po
    with Deans Connector
    • DYN5352D 7.4V 4200mAh 25C Li-Po
    • DYN5360D 7.4V 5300mAh 25C Li-Po
    • DYN5361D 7.4V 6000mAh 25C Li-Po
    What would be a good choice for the battery as well as a charger. I don't want something super expensive but also something that works
    May 2009
    3,180
    The larger mAh the longer your running time will be so go for 6000mAh.
    I would get 1 4S 5000mAh or larger LiPo with the higher the better C rating, let's say 40C or up.
    Charger that works:
    http://www.hobbyking.com/hobbyking/s...dProduct=11060
    You will need power supply:
    http://www.hobbyking.com/hobbyking/s...idProduct=9205
    Cheers
    DJI Drone Advanced Pilot
    Canada
    Wa
    5,905
    get rid of the Deans
    Billy Graham
    May 2011
    OH
    5
    It looks like that charger is out of stock. Any others? Would these batteries be ok?
    http://www.hobbyking.com/hobbyking/s...dProduct=10285
    Also how hard is it to change the connector? The boat comes with deans but the batteries have bullet.
    Sorry but I'm new to all this. I had a blade cx 3 helicopter before this and it was all very simple
    Wa
    5,905
    just need a good 40 watt soldering iron
    Billy Graham
    May 2009
    3,180
    Most of the chargers on HK website are ok for what you need to do...
    Canada
