Hey guys... I pls want your advise or experiance on the best 4s combo to run between 45-50,well more 50s...lol also the best 6s setup to run the same speed.I dont want to rob a bank but i also dont want junk...thanks for all the advise
i forgot...i have an grim 42x55 prop...thanks
Alloy, there are plenty of threads in this section which have more than adequate info on possible setups... check the race prep thread and JP's thread... both of them have excellent setups. Also gotta give us a little more info.. what are you willing to speed? You looking to run the stock esc or upgrade it? Do you have anything yet? (batteries...motor... etc)
hi i will probally put something like the turnigy 180 esc and have 7.4v 5000mah 40C batteries..also 2 3s 4200 40c batts.so actually i want to know what motor wil work in that speed range that i posted about
Big discussion has been going on about voltage vs. speed. Here is a helpful chart (courtesy of Dies) to give you a standard of what you should be doing. Realistically, you should be able to great 50 or near there on 4s. You can work on that prop to give it more speed but it'll take some testing. I myself have a setup waiting at home that is an 1800kv outrunner, 125amp esc, 30-40c batteries with a m445 prop. I'm expected to be running around 45 mph. That should be something to go off of. Stock I was running around 35 with an x642 and stock setup, so a 10 mph increase off of what I had should be easily attainable. You don't need the 6s setup.. youll hit your goal without it. You can pick anywhere from an 1800kv-2200 kv motor (that's what I'd stick with). Follow the chart but with what you got you should be fine
jac...thanks a lot for your comments on what will work,i really really really appriciate it very very very much lol...i have an cc 2200kv motor but will be on the lookout for something like an 180amp esc on 4s with a grim 42x55...thanks
I forgot to mention the batteries play a huge role too... stock I was using the dynamite 25c, your 40-50c will maintain a higher discharge much better than what I was going with. I don't see why you wouldn't get around 45-48 right out of the gate with that setup
what setup...now everything is still stock,if i can get an t180 esc with the cc 2200 motor i will put that setup in,diesel also told me the ul1 motor is very effisient
I have the ul1 in mine and i dig it. at 60 bucks it's not breaking the bank either, and it will run just fine on a t120 but for the 6s thing you may want to go with the 180. Have the pb motor in a hydro and am really tempted to try her on 6s with an x440/3 or something like that.
http://www.youtube.com/watch?v=FafgQb7cP5M
TheSaughnessy...what speed do you get on 4s and if you have maybe tried 6s what speed,also what esc are you using and batts...actually if you will you can actually tel me your whole setup haha thanks a lot
6s on a ul1 motor is going to be bad news!!! JMO
TheSaughnessy... plz let me know your set up i would really let to do that set up
