Originally Posted by
Dale Koblitz
Do you mean to get on plane like cavitation or is there a electrical hesitation from the esc to motor when you pull the throttle? Are you running the stock system now? Have you taken the motor jacket off and checked to make sure all the holes are free from excess silicone? I had to cut a bunch of little pieces out of mine. Also is the drips while taking left turns and the stream on right and streight aways? Because of the rudder intake being on the right side and this being a race boat meant for right hand turns the pick-up works much better turning right. Oh, but have a seperate pick-up on the bottom of the transom don't you? I also board all the hose connectors out with a larger dia. drill bit along with my rudder pick-up? You can check each part seperately with a turkey baster by taking the tubes off and flushing water through each section to find the problem area!
cooling system solved , got water coming out smooth now , but i still dun get the punch when i full throttle till bout 2 -3 secs , it moves off slow than full power in . from stop to moving off in full throttle is what im refering to , when i fully throttle her , she takes some secs to get going .
~known is a droplet, unknown is the ocean~
