Anyone upgrade their steering servo? I think my traxxas 2056 is shot.Took it apart it smells funny and was warm to the touch.It appears to be not as waterproof as advertised...
But why put just any servo in the boat? A boat that size needs a high torque servo to keep good control at high speeds. The force on the rudder can overwhelm a standard servo, causing funky control in corners, hooking, etc.
A servo with at least 80 oz-in at the receiver voltage supplied is a minimum IMO. The first below should work if you have 6 volts to the receiver. If you only have 4.8 volts to the receiver, then use the second one, which is the better choice either way.
http://www.servocity.com/html/hs-485hb_servo.html
http://www.servocity.com/html/hs-645...ra_torque.html
Hitec HS-645MG is good and cheap!
http://www3.towerhobbies.com/cgi-bin...&P=SM&I=LXUZ89
thats a std size servo lol
a micro servo will be to small and a 1/4 scale to big 0_o
Mine went after 4 packs, I send it in and I'm getting a new one
