Nice clean stable runs!
Very nice running boat but wrong section for video...
DJI Drone Advanced Pilot
Canada
Its also posted under the video section, But as i thought these mini/ micro boats are a bit of a specialized interest i posted it here as well. Didnt mean to break any rules. Martin.
As i have said before im using a $12 3800kv motor at the moment on 3s. I also have another $12 4400kv motor on the way to me that i will run on 3s. So should be lively. Great thing about these cheap motors & esc it dosnt matter if you push to far as they cost peanuts. Martin.
Dont know what type of motors your using but the 450 heli outrunners motors i use will pull silly size props. You just have to make sure you go up on esc size which isnt a problem with these cheap esc. So where as a lot of micro boats would use say a 30-35amp esc you can go up to 60amp or 80amp as their so cheap + your keeping a bigger margin on blowing something but probably will simply because you always wont to push harder still. Speeds addictive dont you know. Martin.
