Results 1 to 8 of 8
Thread: Mini-V Re-Build
    Apr 2011
    MA
    58
    Default Mini-V Re-Build
    Im going to be doing a rebuild of my mini-v and just wanted to check my shopping list:
    Esc: Seaking 35a brushless watercooled
    Motor: Airfield rc 70mm 2600kv brushless
    Servo: T-pro mg9os 9g metal gear servo
    Radio: FlySky FS-GT2 2.4g 2ch
    Rudder/strut: OSE Micro Hardware system http://www.offshoreelectrics.com/pro...prod=ose-80972
    Flex Cable: Octure .098 cable system http://www.offshoreelectrics.com/pro...oct-oc098L-24c
    Coupler: Octura 1/8" to .098 http://www.offshoreelectrics.com/pro...oct-ocfhe18098
    Still need a prop and a new steering boot but how does this list sound to all you experts?
    Dec 2010
    CA
    348
    Please post your results of your set up.
    I'm curious to see how the inline micro hardware performs.
    A lot of the builds I've read about used offset strut and rudders.
    Aug 2009
    tx
    3,534
    I had a 28x47 3100 kx inrunner in mine what are you putting in
    Dec 2010
    CA
    348
    Alex
    I ran the Mini V I got from you for the first time today. What a blast!
    Talk about rediculously overpowered. Oh Man.
    Thank you for feeding the addiction.
    Greg
    Dec 2010
    CA
    348
    Seacraftarioch
    Have you made a decision on your hardware yet?
    I think I'm going to start with the .098 Flex with .125 prop shaft going into the stock steerable outdrive. I'll probably order an X427, X430 and the 431 and 432 in plastic.
    right now with the stock prop I'm getting torque roll from 1/2 throttle on up. Maybe the smaller X427 will help tame that. Hopefully I can prop up from that.
    Greg
    Mar 2011
    ma
    756
    I had a novak mongoose 380 13.5 in my talk about over powered way to much power.
    miss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717
    May 2011
    ca
    5
    Dec 2010
    CA
    348
    Quote Originally Posted by baja flyer View Post
    Dimensions and KV will probably work but an outrunner wont work in the stock mount. You would have to modify the inside of the hull and come up with a mount.
    Nothing is impossible
    Greg
