Results 1 to 2 of 2
Thread: So...what can I expect out of her???
    Apr 2011
    69
    Default So...what can I expect out of her???
    Got MG last week. Was outta town, so Pops has it and is going crazy with it...Running 6s 5000mah 50c with 180A esc and x642 prop. Stock motor for now.
    What can I expect my speeds to be when I get her all dialed in?
    Also, going to get a Castle 1518, what might I expect after that?
    Thanks guys
    I will post some pics after I run in havasu this wknd
    On 6s with that setup... Probably around 50. With the 1518... Probably what around 55? Upper 50s?
    I don't think you'll get much more than 60 out of it... then again, If I recall someone said that stability of the boat would be an issue as it starts to get faster (around 70). It appears the optimal speed for this boat is around 50 mph but really from the stock setup up to that its pretty golden.
