now on zippkit.com for 109$
the kit
http://zippkits.com/~zippkits/index....roducts_id=263
the kit
Kick ass!
now who can build them for those who don't have the time to build
Mine is already part way done!
Being this one is small, maybe I do have the time to build it!
On the type of flex shaft & stuffing tube used in this design does the stub shaft just run in the brass outer tube & the flex in the teflon liner. Does the dog run against the stuffing tube end or is the end load taken against the motor bearings. Thanks Martin.
The prototype used a teflon liner and a thrust washer at the "strut".
The production kits will use no liner, and the motor bearings will take the thrust.
We are working on a stub shaft design that runs directly inside the shaft tube...
Joe
I can answer this.....The stuffing box design decision had absolutely nothing to do with the cost........you just plain and simple do not need a strut cluttering up the transom of this boat......
The JAE design team tested the hell out of this system and it is bulletproof and a strut it is just simply not needed......If reliability was in question,.the JAE design team would never have recommended this system.....
The JAE team is dedicated to lowering the cost of model boating ,but never at the expense of a successful day at the lake.
If you are absolutely convinced you need more support,just take the next size up brass tubing and loctite it over the last couple inches of the stuffing box where it exits the ski.Do this before you cap off the rear of the ski and then seal the tub with it the 5 minute epoxy from the inside.
I will say this again......
The JAE team is dedicated to lowering the cost of model boating ,but never at the expense of a successful day at the lake running a JAE design.
Thanks for reply, Also would you use a washer to take the thrust against the stuffing tube or against the motor bearings as planed. Cant wait to get one of these boats & have some fun with it. Thanks Martin.
Martin,
That will not work unless you have some sort of slip joint [I.E. a square drive coupler] in the driveline system and then......... you would also need to design someway to retain the driveline system in the boat to keep it from sliding out the back of the boat when you let off the throttle....
Taking the thrust at the motor bearings will be no problem whatsoever....
In fact when you install the driveline keep a 1/16" gap in between the drivedog face and the end of the stuffing box/stub shaft bushing assembly.
Rod Geraghty
does the kit come with a esc?
thanks
No.
No electronics are included. Every other part or piece needed is included though.
We will have servos and ESC's available for them soon.
Joe
Thanks Rod, Yes thats how i run my mini monos with the load against the motor bearings on outrunner motors running at 42,000rpm unloaded with no problems at all. Thanks Martin.
when will they be realeased?
April 20th is the expected date providing every thing comes together. Thanks.
Can't wait my wife owes me a bday present and I think I just found it
geeeeez! did they sell out already, or did the date get bumped?
It's bumped until next week, if your signed up for the newsletter there is a wicked sale price. I ordered the motor, battery and 2.4ghz radio from Joe's links for a total of $40.
Namba District 16
How do we sign up for the newsletter
Just go tothe www.zippkits.com website and set up a login and asked to be notified when the boat is available. That will get you the email you need to get the discount.
You don't need a discount to get that kind of pricing on the motor/battery/radio from HK.
Motor is $12.04
Battery is $11.29
TX/RX is $16.59
That's regular pricing listed on the site, not discounted for being a repeat customer too. With me logged in the pricing is:
Motor: $11.18
Battery: $9.49
TX/RX: $15.99
It's amazing what you can get for under $200 now!
.....waiting for that email....when this boat going on sale........tick tick tick...
I have no control over the release of the Mini-Sprint.....get ahold of Joe at Zippkits and ask him
for an update on the release date...... sales@zippkits.com
Has anyone asked Joe (ZippKitts) if he has an updated time line for release? I would like to get a couple of these.
Later,
Mike Ball
I spoke to Joe a few days ago about something else but also asked the latest on the Mini Sprint, Hes still waiting on some parts & said maybe around mid month. Martin.
I like the JAE stuff but for less and all built and two inches larger you can get this:http://www.r2hobbies.com/men/proddet...od=rcbt0401005
It's big brother seems successful.
https://forums.offshoreelectrics.com/...ad.php?t=23946
