Page 2 of 2 FirstFirst 12
Results 31 to 46 of 46
Thread: Destroyed in one second! Traxxas quality control thanks again!
  1. #31
    ma
    8,694
    Is that a FG hull Eggy??? I tought only plastic hulls were supposed to do that....at least according to most opinions on here...
    Many different material boats will break at 50mph. I'm not engineer but the force involved with a 6-7 pound boat crashing at 50mph much be rather strong!
    Steven Vaccaro
  2. #32
    Va
    4,670
    Yes it was a FG Bandit Boats El Lobo IV. It was at about 50 in the front straight just before turn 1 when bam!
    IMPBA 20481S D-12
  3. #33
    Apr 2011
    nc
    8
    yea traxxas does let some quality issuses get by them. such as today i was puttin some decals i bought and i noticed that the graphics on sides of the bottom hull arent even on my boat on side without the water outlet the graphics go all the way up 2 the bottom of the top hull but on the side with the water outlet they only come up a quarter of the way up the side. i have seen in some pics that others are the same but i have seen other that the graphics are even on both sides but idk just rambling i guess
  4. #34
    ma
    756
    Quote Originally Posted by dayne View Post
    That's just so your can go faster!!!! Less weight more aerodynamics....:-)
  5. #35
    Dec 2010
    Ge
    13
    May you got some vacuum in the boat? Did you attatch the hatch with tape? The phemomenon is described here, unfortunatly only in german (the text on the right side)
    http://www.gundert-modellboote.de/katalog/x152.jpg
    They say, that if your boat is hemetic, possibly the prob sucks the air out of the boat (via the tube) which will cause the behavior you showed us. To avoid that they suggest to link the tube with fuel line to the outside of the boat.
    Just an idea.
  6. #36
    I didnt read the link. But it sounds like it refers to a fuel powered boat. And the engine might be sucking all the air out and causing it to implode?
    I don't know how this would be on a FE boat.
    Interesting tho
  7. #37
    9,402
    Quote Originally Posted by egneg View Post
    Bandit boats were known for their not the best quality of hulls. I had a shovel nose that went all soft pretty fast. I had to do alot of reinforcements.
  8. #38
    Dec 2010
    Ge
    13
    Hello JPriami, it refers definatly to FE-Boats.
    The fule tube is not used for real fuel for nitro racing, it is used to transfer air from the tube on which an outlet for grease/oiling is applied to the outside of the boat. This shoult prevent the situation that the prop sucks air via the tube out of the boat. With the line installed the prop sucks the air from outside of the boat via the tube, so no vacuum can occure. In case of flipping the boat the outlet of the fuel (air) line must be positioned, maybe on the transom, in a place which is above the waterline, even if the boat flips.
    The whole phenomenon occures because the will be suction on the frontside of the prop which continues through the tube to the inside of the boat.
  9. #39
    1,969
    I don't own this boat, but I do have a little Traxxas Blast that is currently my rescue boat.
    When I first had the boat, I knew nothing about the hobby and proceeded to run a 5000mah pack on the UNCOOLED brushed motor for 20minutes and burned it up. Traxxas repaired it for free, and sent me a cooling kit to boot.
    Then I sank it once, and burned out the ESC. They fixed that too for a nominal charge, even when this was completely my fault.
    You get what you pay for in terms of buld quality with these RTRs, but so far I've been very impressed with Traxxas customer service.
    It pays off for them, since because of the great service I bought a Slash truck for my son. (Try as we might to destroy that one, the darn thing just won't break...)
    Chief
  10. #40
    Jan 2011
    21
    Most people here would agree with you that traxxas has had great service over the years, but the problems with launching a product that has not been finished nor fully tested, Is another thing.
    The spartan was not ready to be launched, but was launched anyways with over heating problems. and unrelaible electronics.
  11. #41
    Jan 2011
    ND
    155
    Well, well, well...... Another hull failure. Not as dramatic as Justin's but a failure non-the-less. The right side of the deck has detached from the hull. I don't mind following Jutin's lead but this is a bit much
  12. #42
    Lets see
  13. #43
    Aug 2010
    461
    Can't say for sure, but it definitely looks like it hit something in the video.
    I ripped a good chunk of the transom off a smaller fiberglass boat going substantially slower than this just by hitting a twig. It's a HK Small Bolt that was only at about 2/3 throttle.
  14. #44
    yeah looks like you hit something. Ive had that happen on one of my cats. on the rudder. But it just messed up the rudder.
    Then on a hydro that ran into the bank gone wild. busted the transom. So I fixed it then made a aluminum plate to make it stronger that spanned the whole back of the transom.
  15. #45
    Aug 2010
    461
    Oh I saw the twig that I hit AFTER I hit it.. D'Oh! Didn't see it at all before though. It was about 1/4" diameter and about 18" long.
    I put lite ply reinforcement on the inside of the transom and epoxied it all back together, including thin epoxy to seal the gelcoat down.
  16. #46
    May 2009
    535
    Looks and sounds like you could have hit a "roller" and stuffed it...JMHO.
