Is the water intake on the dual drive Toysport Jolly only off the rudder?
If it is -- is the water supply sufficent enough for two motors & two Esc's or should I plan on adding some more?
We did it with a Bang!
Cats Are Where It's At!
Only one water pickup. I would keep the tubing length to a minimum.
Steven Vaccaro
Steven I just tried to add the 8t xl motor to my wishlist and it says out of stock any word on availability?
Would I be better off adding an Octura water inlet?
On my twin Jolly the single water intake is from the rudder and works fine.
Inside the hull I have a T fitting that splits the water left and right to thr two motors.
Graham.
Thanks for the info Graham!
I agree the single inlet is plenty. Send it to the esc's first.
